pinske Posted February 19, 2013 Posted February 19, 2013 Hi, Ive bought a set of wheels for my EP91 (16x7j Adikt Excels) and the centre bore of the alloy seems to small so it wont slide over the centre bore of the hub to make the wheels sit flush against the hub. Its strange as these came off of a starlet to begin with. anyone got any idea what could be the problem? ive not had chance to look properly and only test mounted one on the front. but the hub has a metal ring around the centre. anyone know if this can be removed? sorry if it's a bit vague but im not too clued in on wheels etc can upload pics this weekend if thats helpful? Pinske. Quote
morgey Posted February 19, 2013 Posted February 19, 2013 (edited) If you can measure it, the car should be 54mm.What wheels do you have atm? Edited February 19, 2013 by morgey Quote
pinske Posted February 19, 2013 Author Posted February 19, 2013 ill measure it on saturday mate, and some 15.6.5 TSW paces. just shitting myself incase its not a simple fix :S Quote
morgey Posted February 19, 2013 Posted February 19, 2013 Chances are the wheels you have are honda fitment of 55/56mm which is why you have the small ring on there (spigot ring) remove this and you should be able to fit the new wheels.Most aftermarket wheels need spigot rings to fit to toyotas as they have a very small centerbore in comparison to most other manufactures ;) Quote
pinske Posted February 19, 2013 Author Posted February 19, 2013 thanks man, ill check it out. hopefully thats all it is Sam. Quote
TrisK Posted February 19, 2013 Posted February 19, 2013 If not you can get like 10mm spacers with a centre bore adaption Quote
Aamir Posted November 13, 2014 Posted November 13, 2014 Sorry to bump up an old thread but just to confirm the centre bore is 54 mm on Starlets. Only reason I'm asking is because I'm ordering some H&R wheel spacers soon and I want them to be the right size.Thanks Aamir Quote
