Spoon_tuned Posted February 22, 2013 Posted February 22, 2013 Hi guys this maybe a problem may not be. On my V When idling with heaters on my temp gauage drops down to like about a quarter is this normal as im not sure wether it has a low temp thermostat or not. CheersAidan Quote
mech5107 Posted February 22, 2013 Posted February 22, 2013 The heater uses heat from the engine to heat the cabin. Some drop should be normal, but a quarter is too much... Quote
Danza V Posted February 22, 2013 Posted February 22, 2013 Mine sits at halfway or just below. Your heaters are hot yeah? Does it hold temp when you driving along or does the gauge fall? I had this on my V and my stat was fooked. Quote
Spoon_tuned Posted February 22, 2013 Author Posted February 22, 2013 Mines like a quarter. heats up to half without blowers on. When drivin it sits where it should Quote
Jim* Posted February 22, 2013 Posted February 22, 2013 Could it be worth checking the thermostat? Quote
turbo Grant Posted February 22, 2013 Posted February 22, 2013 Could be the thermostat stuck open. Doesn't take ages to warm up? Quote
Spoon_tuned Posted February 22, 2013 Author Posted February 22, 2013 Doesn't take that long to warm up really bout 10mins to get just above the c line Quote
