Well if you take off the window trim along one of your doors then you should hopefully see a white unoccupied socket near the wing mirror.
To remove the trim.
  • Remove the internal trim off the wing mirror.
  • Pop the door card clips but you shouldnt need to remove it.
  • There will be 2 clips you need to remove. One on either end of the window trim. To remove, turn them a little then pull them out.
  • Next unscrew the one screw in the door handle and slide it out of place
  • The trim should pull up. Just dont move it about too much as you could damage the door handle mechanism.
  • And you should hopefully see the connector.
http://www.toyotagtturbo.com/forums/showwiki.php?title=How+to+repair+Glanza+electrically+folding+mirrors
Or check out this link *face palm*
Try and get the switch with the plug on back of it with some of the wiring,makes it a hell of a lot easier when wiring. So that you can just match colours of wiring to colours on wing mirrors.
Theres a tudior somewhere on forum.
  • 3 weeks later...
