basic list.
pistons,
conrods,
uprated rod bolts,
steel haedgasket,
bearings,
thrustwashers,
genuine toyota engine rebuild kit,
uprated headbolts or studs,
uprated main cap bolts or studs,
machine work to block and head (skimming)
In terms of management let your tuner decide on that,
If your aiming for 300bhp there are lots of turbo kits to choose from but it depends on what your budget is you will also need a better clutch.
Thanks for that. I have basic things like manifold, external wastegate. Turbo back exhaust. Hks fcd. Sard rising rate fuel. Unsure of turbo. How can I tell if its standard or could this one run 300 bhp ? Anything else I need ? Thanks
Oh sorry. Yes got uprated clutch.
stock turbo will produce a maximum of 200bhp if you are lucky,
It will be wise to gain more knowledge about your car before going for big power as your recipie with a fcd and fpr to run 300bhp is heading for disaster.
post some pics of your turbo.
Edited by H_D
