So i got my brackets to fit my civic radiator and while i was at it i decided to change the thermostat at the same time. While removing the housing i sheered one of the bolts and then the other one almost came off and sheered as well!
Anyone done this before and know what did they do to fix it?
I did this on one side also when i changed thermostat i sprayed up what was left of the stud with wd40 put a pair of mole grips on it and wound out what was left of the stud
I have a set of stud extracters. Im in town tomorrow so I could drop them off with you along with some m6 bolts to use i place of studs.
What time you heading into town?
My mate who is a mechanic is coming over tomorrow at 9am to see if he can sort it for me so i'll send you a text if he thinks we would need them! cheers for the offer man!
