when I finish forging my engine I gotta run in it , can I run my setup on stock boost while I run it in ?
which would be a WEPR TD05 ext wastegate on stock boost
or would I be better off running my old setup to run in a CT12 Hybrid with a custom mani and zisco decat on stock boost ?
As long as boost pressure is below fuel cut you should be fine. Although I would probably say run a little under 0.6 bar just to be safe.
Don't be a pussy with the engine either, give it some stick and put it under load. It will be within the first 20 miles or so if anything bad is going to happen.
