Glanza100 Posted March 23, 2013 Posted March 23, 2013 Hi, fitted the boost controler last night, how ever no matter what setting I put the boost at, it's still over boosting.Do I need to turn the actuator right down or do I have the arm right open?At the moment the arm is open and I would have thought the contoller would have limited the boost am I right in this? Quote
TrisK Posted March 23, 2013 Posted March 23, 2013 You can use a boost controller to go lower than actuator pressure. Also boost creep can't be fixed by a boost controller. It's a physical problem with the size of the wastegate Quote
Danb Posted March 23, 2013 Posted March 23, 2013 You can use a boost controller to go lower than actuator pressure. Also boost creep can't be fixed by a boost controller. It's a physical problem with the size of the wastegate boost controller can not run less boost than actuator pressure (think yours was a type) Quote
ep-beast Posted March 23, 2013 Posted March 23, 2013 set actuator at standerd boost .6 and use the ebc to up the boost to a bar or watever u need Quote
AdamB Posted March 23, 2013 Posted March 23, 2013 Had the same problem with a previous blitz unit, turned out the solenoid was fucked and there £250 alone. Quote
Gav_kara Posted March 23, 2013 Posted March 23, 2013 I swear by blitz spec s/r controllers there axe had one on all my cars. Quote
TrisK Posted March 23, 2013 Posted March 23, 2013 boost controller can not run less boost than actuator pressure (think yours was a type) Yes that first can was meant to be a cant Quote
Liam_D Posted March 23, 2013 Posted March 23, 2013 Do you have the pipes the right way around? Mine where fitted incorrect and I kept overboosting. And also is it set to the right actuator/wastegate setting on the back?? Quote
Glanza100 Posted March 23, 2013 Author Posted March 23, 2013 Hi, yes all done now. Turned actuaror down, and used controller to turn it up. Thanks for your help. Quote
