Neo Gold Posted March 23, 2013 Posted March 23, 2013 Yes...if it were lean, you would be running exessive boost levels & melted pistons would be inevitable!.Relax.Let me see a pic of how you patched into the o2 sensor please.. Quote
TurboTobz Posted March 24, 2013 Posted March 24, 2013 You need pics of how to mount the lamda? If so theres a few in my Build thread Quote
john fraser88 Posted March 24, 2013 Author Posted March 24, 2013 its spliced into the top sensor in my decat...is that the ryt place for it? Quote
AdamB Posted March 24, 2013 Posted March 24, 2013 Why have you wired it into the stock existing lambda loom? Unless running an aftermarket ecu to make use of this it's not doing any good really. The sensor itself should be mounted like 36 inches from the turbo I think it is. Quote
WallaceGlanza Posted March 24, 2013 Posted March 24, 2013 If it's a narrowband O2 sensor, which it sounds like, then they're not accurate so you may as well pay no attention to it. Quote
Jamie1st Posted March 24, 2013 Posted March 24, 2013 The stock sensor is a narrow band i believe so wouldn't work right, Ive fitted an AEM Wideband sensor and gauge, can see it in my build Quote
john fraser88 Posted March 24, 2013 Author Posted March 24, 2013 oryt ye its standard,where do i get a wideband from? will that work with my air to fuel gauge i oredy hav? Quote
TurboTobz Posted March 24, 2013 Posted March 24, 2013 No you'll get an entire kit, will be very accurate ad give figures, not just rich or lean. I use a plx dm6 wideband which maps everything out on a live chart, gives warnings led indicators and figure also peaks and mins. Also does a lot more and can be linked to up to 6 modules and display them on the one gauge, it's got a touch screen to toggle through data screens also. Quote
