Ep91kez Posted March 24, 2013 Posted March 24, 2013 Hey guys after abit of advice. I need to replace my pcv valve as I accidentally snapped it =[ and don't have a clue how to remove it.Any help would be great cheers =] Quote
davehart Posted March 24, 2013 Posted March 24, 2013 Very easy they just pull off. The old one may be brittle so be careful not to drop any bits down the hole. Quote
Ep91kez Posted March 24, 2013 Author Posted March 24, 2013 It fell down the hole =\ the cam cover is off the engine is there any way to get to it or is it new cam cover? Cheers for the fast reply =] Quote
waderz06 Posted March 24, 2013 Posted March 24, 2013 I had the same problem but just used needle nose pliers and managed to get the remaining bits out. Quote
akyakapotter Posted March 24, 2013 Posted March 24, 2013 I had to remove the old rubber bung it snapped into bits Quote
Ep91kez Posted March 24, 2013 Author Posted March 24, 2013 I do have another cover but it looks to of had a catch can on it and where the pcv valve usually fits its had a thread put in and a different type of breather thing (vague I know) screwed in to it looks like I could just connect that to the inlet but not sure as I dosent have the valve now it's just a straight through breather valve =\ I am quite new to all this so sorry or my crap knowledge lolAnd thanks for the replys =D Quote
akyakapotter Posted March 24, 2013 Posted March 24, 2013 (edited) That's a race spec cover set up Edited March 24, 2013 by akyakapotter Quote
Ep91kez Posted March 24, 2013 Author Posted March 24, 2013 This is my cover if I've uploaded it correctly lol. Would it work connected as a standard set up from the standard breather to the standard recirc valve and from the non standard breather to the inlet? Quote
Ep91kez Posted March 26, 2013 Author Posted March 26, 2013 Sorted now guys thanks for all your help =] just ended up buying another cover with pcv in it haha Quote
Frankieflowers Posted December 4, 2023 Posted December 4, 2023 On 3/24/2013 at 3:10 PM, akyakapotter said: That's a race spec cover set up http://i164.photobucket.com/albums/u36/akyakapotter/DA219A09-089B-460F-8C4E-1533C94E9289-299-000000342509BA42.jpg Hello! How did you put that 90* in instead pf the plastic pcv? Thanks Quote
