That's the point of an expansion tank?
As it cools it will draw it back into the rad
The mans rite mate it will do that under heavy driving just leave it running for 5 and it will draw it back in
mine has just done this found my radiator was cracked and leaking causing coolant to boil at normal temp and force its way out through the rad cap. check all you pipes and radiator first then start replacing stuff cheapest first rad cap thermostat etc
