td04 glanza Posted April 8, 2013 Posted April 8, 2013 I removed the engine somewhat months ago and fired a new one in at the weekend but im left with a few pipes, sensors etc that im not sure about if anyone has any help it would be greatly appreciated 1) Firstly this is on the front of the block and i cant see anything that plugs into it, What is it and does it need to be connected? 2) The two blue prongs? Dont have a clue what they are? they are just under dizzy. 3) The grey triangular electrical connector? what is it and does it need to be connected? 4) Not sure what this is but it has two vaccum hoses connected to it and one isnt connected to anything! 5) The two red and black prongs, what are these? Im guessing they are some sort of vacuum? Any help would be great im trying to get it running for next weekend so just want to clear these up asap Allan Quote
yaristurbo Posted April 8, 2013 Posted April 8, 2013 (edited) 1 oil pressure. Yes stops oil light2 after market???3 water temp( ecu) might be dash? ????4 vac solenoid 5 can't really tell dont use standard vac system Edited April 8, 2013 by yaristurbo Quote
td04 glanza Posted April 8, 2013 Author Posted April 8, 2013 Cheers dude thats a great help, rep added Quote
morgey Posted April 8, 2013 Posted April 8, 2013 2) My old n/a 1.3 had this on it. I think they went into the dizzy or somewhere silly like that.3) i think thats multiple water temp sensor. Ecu and dash temps both on one plug (or maybe the fan cut is one of them) Gt's use individual sensors for each i think. Quote
Asad Posted April 9, 2013 Posted April 9, 2013 1- oil pressure2- charcoal canister valve, closes/opens as the engine warms up3- water temp related4 + 5 are air con related iirc all but 1 and 3 can be removed and in the case of 2 leave it in Quote
td04 glanza Posted April 9, 2013 Author Posted April 9, 2013 So is this an na thermo housing?? Cheers for replys guys its appreciated Quote
daniel_g Posted April 9, 2013 Posted April 9, 2013 You can get rid of 4 and 5, well i have. Ditch the carbon canister thing and block up the two unneeded nipples on the throttle body. The thermostat housing you use has to match up with the loom you are using. For example im using a 98 spec V FTE in a GT but with a GT thermostat housing. Quote
td04 glanza Posted April 9, 2013 Author Posted April 9, 2013 Ah that coukd well be why the electrical connector is different then dan cheers will have a look at that saturday. Quote
daniel_g Posted April 9, 2013 Posted April 9, 2013 Chuck all this.You'll have to remove the coil ignitior for the king lead from this as it uses the same bracket on the bulkhead.And block off the top nipples on the throttle body like this, or use hose and bolts. Quote
daniel_g Posted April 9, 2013 Posted April 9, 2013 1st pic is number 5 ^ upside down 2nd pic is a close up of a throttle body. Quote
