Map sensor, lambda bung, hub nuts
As above, need a map sensor for ep91 and could do with the little black diaphragm thingy that goes in the vac pipe.
Also need a lambda bung as my down pipe has room for 2.
Edited by Lew91
The hub nuts or the drive shaft ones, the big 32mm Basterds lol.
I can't remember the proper name for them :/
Edited by Lew91
