I'm going to fit my boost gauge tomorrow and have had a quick look on the how2 section but am still not sure where to connect the vacuum t piece,
I presume this is because I have a air filter relocation kit and a Bailey dumpvalve so the hoses have been relocated else where.
Where do I tap the vacuum feed from now, or would you need a pic of the bay,
Any help appreciated. Cheers
Get a T piece that you'd use for a windscreen wiper washer hose, and cut in half the vacuum from the dump valve and insert the T piece then join back up the dump valve to the T piece and then you have 1 spare exit for your boost gauge for some more vacuum to come off.
As said above, there are literally tons of vacuum sources.
Ok cheers for clearing that up for me, feel like a bit of a div now but at least I know now.
I'll see what's suitable then when I have aanother look tomorrow.
I'll just
There are loads of vacuum lines! Easiest one is probably the small one off the inlet manifold, it's nice and close to the bulkhead.
