g14nza Posted April 12, 2013 Posted April 12, 2013 Please help me ASAP I'm on the last stages of finishing my car but I've got a few things that need to be sorted I don't know where the pipes are to connect up.As you can see in the pic it's on the stat housing either I'm being stupid and blind :sAlso on top of the dvAnd on the back of the intake manifold.. Last of the list is the vac solenoid where do they connect to as at the moment there on the throttle body and fuel filter :s That's all guys please help me really wanna get it started tonight Quote
daniel_g Posted April 12, 2013 Posted April 12, 2013 The one on the thermo housing should go through the bulkhead to the heater matrix, or i just have it going straight to the pipe that comes off the side of the water pump pipe. The nipple on the back of the inlet i have going straight to the map sensor directly above it. The nipple on my hks dv connects via a vac hose to a nipple on my inlet, on the front nearest the drivers side. Not 100% but that how mine is and its ok. Quote
RobSR Posted April 12, 2013 Posted April 12, 2013 (edited) On 4/12/2013 at 5:22 PM, daniel_g said: The one on the thermo housing should go through the bulkhead to the heater matrix, The nipple on the back of the inlet i have going straight to the map sensor directly above it. The nipple on my hks dv connects via a vac hose to a nipple on my inlet, on the front nearest the drivers side. Not 100% but that how mine is and its ok. Yup thats right. Edited April 12, 2013 by RobSR Quote
