t-j-wilson Glanza V Posted April 12, 2013 Posted April 12, 2013 Hey guys, I've had a knocking noise coming from my outer CV joint so been looking to replace both driveshafts fully to be safe. Then i was thinking if i was to replace both inner and outer joints on both shafts it'd be better then risking second hand shafts which could have the same problem,,, Could anyone shed any light whether this item on Camskill is both inner/outer joints, so one side complete etc? Their pictures say inner and outer but item title says outer? And also the 23/30 splines... http://www.camskill.co.uk/m19b0s1304p9670/TOYOTA_STARLET_TURBO_%28EP82_EP91%29_-_SERVICING_PARTS_TUNING_SPARES_and_SERVICE_ACCESSORIES_-_Outer_CV_Joint_Kit_-_23_30_Splines_-_Toyota_Starlet_Turbo_EP82_EP91 Many thanks, Tobie Ps i need this sorted so i can make it to japfest ;) Quote
morgey Posted April 12, 2013 Posted April 12, 2013 Thats an outer cv joint, the hub with b either 30 spline and the driveshaft 23 the other or visa versa Quote
t-j-wilson Glanza V Posted April 13, 2013 Author Posted April 13, 2013 Ok mate thanks for the help. Quote
mattyD Posted April 13, 2013 Posted April 13, 2013 No one sells inner joints apart from Toyota mate, expect to pay a fair price for them as well Quote
Matt1878 Posted April 13, 2013 Posted April 13, 2013 If the CV joint is knocking ( when you turn your wheel, mainly on full lock) then the item you are looking at, CV joint 23/30 is what you need My car had the same problem when I bought it. Got 2 new joints for each side from cam skill and had no problems since Quote
Matt1878 Posted April 13, 2013 Posted April 13, 2013 Well mine is a 97 glanza ABS model. That was the correct spline count for me Quote
t-j-wilson Glanza V Posted April 13, 2013 Author Posted April 13, 2013 Thanks Guys so much help, you've now made up my mind on what i'm doing I'm guessing my 98 ABS V will be 23/30 splines also? Did you have any trouble replacing them or was it pretty straight forward ?Thanks alot , Tobie Quote
