starbogt Posted April 14, 2013 Share Posted April 14, 2013 Hi guys need a little technical help. I have a stiff gear change but only in gears 1 2 5 I've recently replace knackered gear linkage bushes with bearings and turned the chocolate block. It was stiff before but not this stiff. Any ideas other than lots of grease? The cables seemed loose enough the mechanism in car was free! Quote Link to post Share on other sites
yaristurbo Posted April 14, 2013 Share Posted April 14, 2013 Pull the cable off the gear box and check how stiff it is... That will tell which part it it cable selector unit or gearboxCould be selector or seizing shafts Quote Link to post Share on other sites
starbogt Posted April 14, 2013 Author Share Posted April 14, 2013 Checked them all this morning and all feels free so I greased it all even the gearbox side, felt fine so I think it may be the bearings not sitting straight on the selectors... I tried the gear change without being clipped on and it was OK so I'm guessing its related to cable to gearbox connection. Going to change gearbox oil to eliminate that side. But any more ideas wouldn't go amiss :-) Quote Link to post Share on other sites
starbogt Posted April 14, 2013 Author Share Posted April 14, 2013 Anyone that has used the bearings on selectors can you tell me how many large and small washers you have used either side of the bearing? Quote Link to post Share on other sites
har-vey Posted April 14, 2013 Share Posted April 14, 2013 I'm using bearings now and I'm not happy with them. If I could find polybushes to replace them with i Would. Mine is stiff from side to side. Quote Link to post Share on other sites
starbogt Posted April 14, 2013 Author Share Posted April 14, 2013 What amount of washers are you using on it? Side to side action is OK on mine but still stiff into gears with them! It must be to do with the bearing being straight! Quote Link to post Share on other sites
har-vey Posted April 14, 2013 Share Posted April 14, 2013 I haven't had a good look at it yet. I was thinking of going back to the rubber bushes if I can't get hold of polybushes. Would be interested to see if changing the amount of washes makes much difference. Quote Link to post Share on other sites
starbogt Posted April 14, 2013 Author Share Posted April 14, 2013 I only use 1 small then 1 large then other side 1 large and 2 small as with the 3 as specified it was too tight going to alter them when I get more time Quote Link to post Share on other sites
har-vey Posted April 14, 2013 Share Posted April 14, 2013 I think that's the same as me, I couldn't get them all on. I'll have a look tomorrow and let you know Quote Link to post Share on other sites
starbogt Posted April 14, 2013 Author Share Posted April 14, 2013 Cheers Quote Link to post Share on other sites
rob_bower Posted April 15, 2013 Share Posted April 15, 2013 FYI poly ones used to be available off eBay. Let me know how you get on andy. Quote Link to post Share on other sites
DaddyDutch Posted April 15, 2013 Share Posted April 15, 2013 I'm having the same problem after changing box a few months back.Side to side is stiff, esp after a few days of car not moving, and it's hard to get reverse.Was wondering what it might be.I'll check it out later. And what's the chocolate block, Do you mean the sugar cube under the linkage arm? Anyone got a link for the poly ones?? Al. Quote Link to post Share on other sites
starbogt Posted April 15, 2013 Author Share Posted April 15, 2013 Yes. ugar cube lol oops. Mine seems a bit looser when I've driven a while as though its better warm! Mmm it seems less direct into gear too so I think I need to mess around and see what I find. Keep me updated if you figure yours out Quote Link to post Share on other sites
DaddyDutch Posted April 15, 2013 Share Posted April 15, 2013 Yes. ugar cube lol oops. Mine seems a bit looser when I've driven a while as though its better warm! Mmm it seems less direct into gear too so I think I need to mess around and see what I find. Keep me updated if you figure yours out Ha. No probs mate. Mine's is the same once I'm driving a bit it's fine. Will do, same goes for yourself. Quote Link to post Share on other sites
starbogt Posted May 3, 2013 Author Share Posted May 3, 2013 (edited) Update : small washer large washer then bearing all greased then small washer large and then small then pin. while off I took the forked pin that holds the cable housing off and rotated the gear cables 45degress in either direction,and then re fitted everything but didn't press the forked pins in as hard as possible just enough to hold them in place and the gearchange is spot on nice and smooth and free. Also tried changing gearbox oil which made a small bit of difference. Edited May 3, 2013 by starbogt Quote Link to post Share on other sites
rob_bower Posted May 3, 2013 Share Posted May 3, 2013 Glad you got it sorted mate. Quote Link to post Share on other sites
tiksie Posted May 6, 2013 Share Posted May 6, 2013 Hey mate Did you have any images of where you installed the washers and greased up ? I'm yet to sort out my issue of not being able to get into 5th and reverse, but it seems my selector won't go side to side, just to the left and only a tiny bit to the right which I think is to do with linkages. Pics would be awesome! Thanks Quote Link to post Share on other sites
