When I had my old black GT and had half my stand alone installed. I changed back to stock ecu. Tryed to drive it up the road and it made it rev up down up down. Had the tps unplugged still. Mick be worth checking the tps with a volt meter. See if its still switching ok
It's the TPS. When you slightly press the gas pedal, the TPS movements is not enough to "leave" the idle contact and the ECU cut fuel when reaching over 1500-1800rpm like fuel cut when decelerating in gear.
I suppose there is also a slight hesitation when in gear you press the gas at around 1500-2000rpm.
Adjust the TPS and will sort out.
