Breather filter on rocker chirping
I recently removed the efi pipe and put a breather on the rocker and its chirping away like jimny cricket has been sucked through the bonnet scoop can only here it when idling and I've tried two brand new different breathers Is this normal ?
Thanks
Seems strange I tried to brand new breathers of different brand aswel and same sound coming from them it's not spitting oil is running fine just chirps away in traffic or on idle :/
Yet it wasn't making this noise when the standard recirc was connected to the efi pipe
How can I tell if the Pcv valve is blocked ?
Edited by Lawless
It has got a jubilee clip on the breather it's not done up overly tight because I don't want to damage the little bit of pipe it sits on not tried it with the breather off but before fitting it there was no noise coming from the standard recirc valve and it literally only chirps cars running fine just wanted to make sure this was normal or if I've done something wrong
Thanks
Mine does it as well. I thought it was just air through the filter tbh.
I still have the efi pipe etc, just fitted the breather as i have a different bov.
Im sure ive seen videos of other engines doing the same. May have been one by taggy?
