Cheers mate, have the glove box and centre bit out, need to take the clocks out still.. Do i need to take the heater fan and shit out 1st? cant seem to find the bolts for it
To remove the actual dash, theres a bolt behind the time clock, one behind the instrument cluster ane one either side of the car. Then theres four pink push clips that run along the bottom of the window.
Thanks daniel, once i get the bolt behind the clock and dails can i just pull the dash from the push clips?
Youre best to stick a long screwdriver to push the release tab on the clip itself, otherwise the clip might snap and you'll end up with an irritating rattle.
Pretty sure you can leave the fan box in though.
