My radio,mirrors,clock and cigarette lighter all stopped working at the same time, after some research I relised I had to replace the RAD fuse. I replaced it but after a day it blew again, now whenever I put the fuse in then turn the key it blows instantly, can anyone help?
Had this on mine, turned out the cigeratte lighter was shorting out.
Check all the wires behind it and makes sure you've got the right lighter in it, also check the head unit wires aren't exposed and shorting out any where
You'll need to remove the plastic trim around the gear lever, it's only a few screws and it'll come out with that.
