hey guys.
im looking to replace the worn out soft springs in my starlet and need some opinions about what springs you guys are using ie what makes of springs and opinions and feed back on them
thanx in advance for any input
I've heard nothing but excellent feedback for the Pi lowering springs which are available from Ebay ;)
I personally am using TRDs and think they're awesome :p
check out tobys store for lowering springs,
rs*r for comfort
whitline for a mix between confort lowering stance
teins for ride handling
check tobys store on the forum ;)
If your looking for an upgrade then it's wise to consider shocks as well. Lowering springs will put a lot of strain on old worn oem shocks. The spring rates are also unmatched meaning she won't handle well and ride quality will be poor. Lowering springs are okay as a cheap fix but most will end up buying shocks in the long run.
Something like the Koni Adjustables with Whiteline or Tein springs is a good match as there quite similar. After this your best bet is either a s/hand set of coilovers from yahoo auctions or a new set. We also sell KYB shock absorbers but these are stock replacements so are not really suitable as mentioned before.
If you need any help don't hesiate to ask.
Kind Regards,
Toby
