right so i have this problem, im running an avcr boost controller with my ct9, no matter what i changed on the settings, made no different to how much boost i could run, so i unplugged the solenoid vac pipes and just connected the actuator to the turbo so it runs off the wgate pressure, still no difference? when i adjusted the actuator it just ramped up faster, but no more than .7 bar no matter what? anyone please? :(
From the way I read that the problems there with the avcr off, so shouldn't be a problem with the controller. But it's not incredibly clear
well the first part of what i wrote said "im running an AVCR and no matter what i changed on the boost settings, it didnt change anything" which is why i unplugged it to see if there was a problem with the avcr, so i just connected the pipe that goes from the turbo to the actuator, its still the same, and when i say ramps up, i mean how fast the boost builds up, i hit full boost within a split second when i plant my foot, any suggestions?
Are you trying to boost lower than the actuator pressure? I know it silly but some people think you can.
Do you know that the avcr is working properly? Maybe worth testing the solenoid
Is it an adjustable actuator?
sorry not sure what you mean by trying to boost lower lol :p the avcr is working ive checked it all over, and yes hks adjustable actuator :)
not sure people are reading any of this properly, nothing changed when i unplugged the avcr and ran it off the actuator pressure...
