right so i have this problem, im running an avcr boost controller with my ct9, no matter what i changed on the settings, made no different to how much boost i could run, so i unplugged the solenoid vac pipes and just connected the actuator to the turbo so it runs off the wgate pressure, still no difference? when i adjusted the actuator it just ramped up faster, but no more than .7 bar no matter what? anyone please? :(
well the first part of what i wrote said "im running an AVCR and no matter what i changed on the boost settings, it didnt change anything" which is why i unplugged it to see if there was a problem with the avcr, so i just connected the pipe that goes from the turbo to the actuator, its still the same, and when i say ramps up, i mean how fast the boost builds up, i hit full boost within a split second when i plant my foot, any suggestions?
Are you trying to boost lower than the actuator pressure? I know it silly but some people think you can.
Do you know that the avcr is working properly? Maybe worth testing the solenoid
Is it an adjustable actuator?
