roachburger Posted June 9, 2013 Posted June 9, 2013 Dunno what's going on I start the car, ticks over fine no smoke, lovely on or off boost or when driving as soon as its warm and I stop and leave the car to idle I'm engulfed in nasty white smoke ..I've got no mayo in the rad or rockerNot using any fluidsOils clean and was changed a week ago along with filter.I snapped the pcv on the rocker and it gave me some lovely blue smoke so I blocked the inlet hole and dug out the pcv and put a breather pipe in.It's calmed down but still loves me.My intercooler pipes are clean and dry. On a ct9 standard wastegate, no boost control, 0.6 bar, downpipe and maybe 2" straight through exhaustAnyone got any thoughts ? Quote
daniel_g Posted June 9, 2013 Posted June 9, 2013 White smoke suggests water, so its probably either condensation or coolant. Quote
roachburger Posted June 9, 2013 Author Posted June 9, 2013 Yeah its too thick to be condensation .. and it doesn't appear to be using any coolant, this is why I'm blagged, anyone got a picture of the inlet pipework aka coolant pipe I know its a common mix up Quote
daniel_g Posted June 9, 2013 Posted June 9, 2013 This is a pic of the TB pipes on my GT when i was building it up.Should be clear enough to make out. Quote
5T4R7ET N/A Posted June 9, 2013 Posted June 9, 2013 try removing the PCV valve or replacing it. Quote
roachburger Posted June 10, 2013 Author Posted June 10, 2013 There's some liquid in my turbo not worked out what it is tho I was too frustrated and gutted I've just walked away and left it in bits .. any thoughts boys, head gasket or turbooomm ? Quote
Crooks Posted July 22, 2013 Posted July 22, 2013 Mines doing the same drives fine no smoke am then idles white smoke tbh honest smells oily. Going to compression test here if all good got another turbo change it and it not that head gasket Quote
