Jamie-GlanzaV Posted June 15, 2013 Posted June 15, 2013 what does this sound like, could it be the seals on the turbo, have only nursed her 2 mile a day the past week and there has been no smoke its only when i give her some and there is plenty of smoke lol and loads in idle after aswell, slight oil smell of the smoke, put a decat in her last week and a new lambda too, could i have upset something? Any help would be great thanksJamie Quote
TurboTobz Posted June 15, 2013 Posted June 15, 2013 Oil burning is usually more blueish. Whites usually a sign of water so headgasket is usually the issue. If your losing power though and it's smoking I'd check compression and check the turbo over with your fingers to see if you can spin it by hand and if it has much play up and down and in and out. Quote
Jamie-GlanzaV Posted June 15, 2013 Author Posted June 15, 2013 Cheers hopefully not the head gasket lol Quote
Stu Posted June 16, 2013 Posted June 16, 2013 If the white smoke has a pungent smell it's likely to be the turbo seals - its fairly common with ct9's. Monitor the water and oil if you think its a head gasket - should see the tell tale signs.You could always get a PK test done to confirm Quote
Liam_D Posted June 16, 2013 Posted June 16, 2013 Yeah as said, white smoke is usually water related so check headgaskets and make sure it's not just condensation. Turbo is normal blue smoke. Quote
Jamie-GlanzaV Posted June 17, 2013 Author Posted June 17, 2013 cheers for the help lads, over the past few days there hasnt been much smoke at all and not losing that much power but there is still a smell, maybe get a chance to get checked today. Quote
