Hi ive come to fit my race tech braided oil line, and when i removed my old one the banjo bolt only had 1 washer, the bit it screws into thats bolted to the block is threaded about 3/4 the way down so i can only assume that the washer was removed so the banjo bolt could bite into the decent threads.
New to starlets but have mechanical knowledge, am just wondering what i need to replace and where to get it from?
Thanks
Ideally you want a new washer on both sides of the banjo fitting the other one probably just got dropped! They're just 16mm (I think) copper washers, easy to get.
Edited by WallaceGlanza
I have new washers, the previous owner must of fitted it without both washers because the inside of what i belive to be the oil filter housing? has threaded part way in. The banjo bolt will only catch the threads with 1 washer removed..
I was wondering where i can get a new oil filter housing from?
