Barneyboy1997 Posted September 17, 2007 Posted September 17, 2007 Ive got a ep91 n/a was was wondering if it was possible to fit glanza brakes to it easy enouth? ie new standard glanza calippers and upgraded disks and pads. Also proberly coverd before but is it hard to install disks to tut rear? Problem is i wanna keep 14's on so dont want huge disks. Any info welcomed.Many thanks AJ Quote
SiCaln Posted September 17, 2007 Posted September 17, 2007 i believe the Glanza uses the same calliper as the SR Quote
Tintin_SR Posted September 17, 2007 Posted September 17, 2007 Yeah, you just need the brackets from the turbo model in that case. Some of the lower spec NA's will require the whole unit though...so what will the SR need? Quote
SiCaln Posted September 18, 2007 Posted September 18, 2007 the later spec already have the same brake setup Quote
Barneyboy1997 Posted September 18, 2007 Author Posted September 18, 2007 Mines a 97 sportif so i'll need the complete set up then. What disks and pads would you think will be value for money?Many thanks Quote
SiCaln Posted September 18, 2007 Posted September 18, 2007 I have used ebc greenstuff pads and ebc discs in the past, but I've heard good things bout mintex pads and 3g discs Quote
Nanglebadger Posted September 20, 2007 Posted September 20, 2007 mine's a 98 and had the same calpiers a glanza.EBC greenstuff FTW! I was warned off mintex tho alot of folk on here seem to like them.Blackdiamond make discs but 3G is the popular option.Phil. Quote
Barneyboy1997 Posted September 21, 2007 Author Posted September 21, 2007 mines got brembo disks and nearly new genuine toyota pads but the brakes are crap. i bleed the fronts but still no good ;) Quote
