starletgt-shady Posted June 18, 2013 Share Posted June 18, 2013 what is this on the side of the intake manifold and what does it do? do I need It?thanks for any help Quote Link to post Share on other sites
JordanEP91 Posted June 18, 2013 Share Posted June 18, 2013 Fuel pressure reg mate Quote Link to post Share on other sites
starletgt-shady Posted June 18, 2013 Author Share Posted June 18, 2013 Do I need this if I have a sard rrfpr. Can I get rid of it ? Quote Link to post Share on other sites
Lew91 Posted June 18, 2013 Share Posted June 18, 2013 Idle control valve isn't it? http://www.toyotagtturbo.com/forums/showthread.php?57564-Idle-Control-Valve-Removal-and-cleaning Quote Link to post Share on other sites
TurboTobz Posted June 18, 2013 Share Posted June 18, 2013 Icv not fpr. You do really need it yeah. Quote Link to post Share on other sites
starletgt-shady Posted June 18, 2013 Author Share Posted June 18, 2013 How would I use this on an uprated manifold as there ain't a place for it go? Quote Link to post Share on other sites
iamlegend Posted June 18, 2013 Share Posted June 18, 2013 lol... idle control valve indeed... will make a ticking noise.. give it a clean Quote Link to post Share on other sites
starletgt-shady Posted June 19, 2013 Author Share Posted June 19, 2013 Anyone? I have a zisco uprated manifold and just want to know how I use the icv with it? Quote Link to post Share on other sites
Lew91 Posted June 19, 2013 Share Posted June 19, 2013 Isn't it not needed? I thought you can just control the idle with the TB. Quote Link to post Share on other sites
DevonGT Posted June 19, 2013 Share Posted June 19, 2013 On 6/19/2013 at 9:19 AM, starletgt-shady said: Anyone? I have a zisco uprated manifold and just want to know how I use the icv with it? You can't, unless you make up your own bracket. There's a screw you can use to adjust the idle if need be on the TB I think. Quote Link to post Share on other sites
starletgt-shady Posted June 20, 2013 Author Share Posted June 20, 2013 anyone know what this is? is it needed?any help be great trying to get things tidied up and fit new manifold http://s1290.photobucket.com/user/starletgtshady/media/Mobile%20Uploads/IMG_2800_zps43cb0d89.jpg.html'>http://s1290.photobucket.com/user/starletgtshady/media/Mobile%20Uploads/IMG_6125_zps44bedffe.jpg.html'> Quote Link to post Share on other sites
starletgt-shady Posted June 20, 2013 Author Share Posted June 20, 2013 Anyone for ideas? Quote Link to post Share on other sites
Lew91 Posted June 20, 2013 Share Posted June 20, 2013 I've done away with pretty much all that Quote Link to post Share on other sites
starletgt-shady Posted June 20, 2013 Author Share Posted June 20, 2013 I'm guessing its not really needed? Any ideas what it is? I Got rid of the air con bits. Quote Link to post Share on other sites
Lew91 Posted June 20, 2013 Share Posted June 20, 2013 Boost solenoid, I cut the plugs off for the air con as well and taped them up. Charcoal canister can go as well and if your willing get an inline fuel filter and get rid of the big ugly one on the firewall. Quote Link to post Share on other sites
starletgt-shady Posted June 20, 2013 Author Share Posted June 20, 2013 What's the charcoal canister? Quote Link to post Share on other sites
Lew91 Posted June 20, 2013 Share Posted June 20, 2013 The big ugly black thing next to the fuel filter Quote Link to post Share on other sites
starletgt-shady Posted June 20, 2013 Author Share Posted June 20, 2013 Ok cheers that's great. Is that the one with the thin vacuum lines going to it. Most of the lines going to the throttle body can get blanked of then?? Quote Link to post Share on other sites
Lew91 Posted June 20, 2013 Share Posted June 20, 2013 (edited) Yeah that's the one, there will be a hard line going to it from under the car as well you'll want to put a uni flow valve on that, there about a fiver off eBay. Yes plug all the ones coming off the TB and it should'nt affect the idle. Edited June 20, 2013 by Lew91 Quote Link to post Share on other sites
starletgt-shady Posted June 20, 2013 Author Share Posted June 20, 2013 Thanks for all the help mate. Just had a quick look and ebay loads of different ones. Do you have an idea which uni flow valve I need? Thanks again Quote Link to post Share on other sites
Lew91 Posted June 20, 2013 Share Posted June 20, 2013 I just got this one but in black Looks like this atm but I'll hide it later on before the engine goes back in. Quote Link to post Share on other sites
starletgt-shady Posted June 20, 2013 Author Share Posted June 20, 2013 Thanks mate cheers Quote Link to post Share on other sites
Lew91 Posted June 20, 2013 Share Posted June 20, 2013 No worries mate Quote Link to post Share on other sites
