Lawless Posted June 21, 2013 Share Posted June 21, 2013 Trying to seal the hot pipe for the fimic is proving to be a royal pain in the arse was going to try using some sealant but not sure which to use as it gets quite hot can anyone recommend anything Quote Link to post Share on other sites
StuDoc 72 Posted June 21, 2013 Share Posted June 21, 2013 NONE! You cant put sealant on your intake system. Which part are your struggling to seal? Is it CT9? There should be a gasket. Quote Link to post Share on other sites
Lawless Posted June 21, 2013 Author Share Posted June 21, 2013 It's the point where the flange on the intercooler would bolt on to the ct9 the studs don't seem long enough and can just about get the nut to bite the thread the gaskets still there but while trying to boost all I'm getting I's areal high pitched whistling I can only pressumr it's this part as the rest of it all seems sound spent last couple of nights trying to sort it can't seem to in the cause can I just thread a Long nut and bolt through there or do I have to use the studs provided Quote Link to post Share on other sites
StuDoc 72 Posted June 21, 2013 Share Posted June 21, 2013 So its where the hot pipe bolts on to the CT9? If its due to the studs being too short then take them out and replace them with bolts as its obviously threaded you wont need nuts. Just DON'T use sealant. Quote Link to post Share on other sites
Lawless Posted June 21, 2013 Author Share Posted June 21, 2013 Ok mate thanks Quote Link to post Share on other sites
StuDoc 72 Posted June 21, 2013 Share Posted June 21, 2013 Good luck bud. Quote Link to post Share on other sites
akyakapotter Posted June 21, 2013 Share Posted June 21, 2013 Why not stu doc ? I used black loctote sealant on my old ct9 set up was fine used common sense and didn't go mad with it worked a treat Quote Link to post Share on other sites
Lawless Posted June 21, 2013 Author Share Posted June 21, 2013 That's what I was thinking was gonna go grab a tube of locktite sealant and just smooth a fine layer over gasket and pipes but not go crazy with it but ill try removing the studs first otherwise I have no other option but to use sealant or put the top mount back on Quote Link to post Share on other sites
StuDoc 72 Posted June 21, 2013 Share Posted June 21, 2013 (edited) Why not stu doc ? I used black loctote sealant on my old ct9 set up was fine used common sense and didn't go mad with it worked a treat Shouldnt have any type of sealant on the intake side of a cars aspiration system. Ofcourse you can be careful but its proper practice not to. They use gaskets for a reason. All it takes is 1 little bit to get sucked through and you could have big problems. Same reason you dont use exhaust paste before the turbo. Edited June 21, 2013 by StuDoc 72 Quote Link to post Share on other sites
Lawless Posted June 21, 2013 Author Share Posted June 21, 2013 Ill try changing studs first otherwise top mount will go back on dint want to cause anymore problems cheers For the advice Quote Link to post Share on other sites
Jhandy Posted June 21, 2013 Share Posted June 21, 2013 if you need a gasket, just make one out of a cereal box, no harm can be done then Quote Link to post Share on other sites
StuDoc 72 Posted June 21, 2013 Share Posted June 21, 2013 if you need a gasket, just make one out of a cereal box, no harm can be done then This^ Far better than using sealant. It should defo seal though mate. Mine sealed even without a gasket. Maybe leaking from 1 of your pipe joints. Quote Link to post Share on other sites
StarletSr? Posted June 21, 2013 Share Posted June 21, 2013 Yea I used a gasket paper just to be on the safe side I understand what your saying about the bolts to I went and brought longer ones for mine still not happy with it. Quote Link to post Share on other sites
Lawless Posted June 21, 2013 Author Share Posted June 21, 2013 Ill make a gasket and change bolts can't seem to see any splits or damage on the pipes and only been doing this since I tried to adjust the flange fitted this kit Sunday and been pudding about with it since just want my BOOST back Quote Link to post Share on other sites
StuDoc 72 Posted June 21, 2013 Share Posted June 21, 2013 What did you fit on sunday? an FMIC? It could be leaking from any of the joins on the pipes if they arent all every tight. What flange and why did you try and adjust it? Quote Link to post Share on other sites
Lawless Posted June 21, 2013 Author Share Posted June 21, 2013 I say flange I mean where the hot pipe joins the turbo I fitted the fimic and mines ecu but that wouldn't have anything to with a boost leak After I initially fitted it I found it was under boosting and that there wasn't a decent amount of thread in the nuts was literally only grabbing the top so I took the hot pipe off made sure it was lined up ect and put it all back on since then it's making a whistling noise and boosting even less Quote Link to post Share on other sites
StuDoc 72 Posted June 21, 2013 Share Posted June 21, 2013 Cool well defo put the hot pipe on with better bolts but I've never found it very hard to seal. Then make sure all your piping clamps are nice and tight. Quote Link to post Share on other sites
Lawless Posted June 21, 2013 Author Share Posted June 21, 2013 Will do again thanks for the advice dude Quote Link to post Share on other sites
webby Posted June 21, 2013 Share Posted June 21, 2013 I use something called heatmate it's great stuff it's stinks but it's good just don't go mad with it Quote Link to post Share on other sites
