H_D Posted June 27, 2013 Posted June 27, 2013 (edited) For sale: Very rare ZEP pnp ecu EP91Item Condition: goodPrice and price conditions: £550 ono + 4% paypal feesExtra Info: This is probably one of the rearest pnp ecu's available i have only seen 3 in the last 4 years. It removes speed cut and fuel cut, raises rpm to 8500, advances ignition after 5000rpm. It has a very aggressive map. There are no seals on these ecus so i have taken pics of it in comparison to a stock ecu the daughter board on the ZEP is clearly visible. (mounting brackets not included)Pictures:Contact Details: PM or txt on 07905398789Location: Leicester.Delivery & Conditions of Delivery: Collection would be preferred so you can try and test it before buy for extra piece of mind or £10 next day signed for delivery via royal mail.Thanx for looking. Edited June 28, 2013 by H_D
Socks Posted June 28, 2013 Posted June 28, 2013 You do realise that opening these ecu's is a bad idea... The additional chip has a UV sensor which wipes if exposed to light... i believe...
H_D Posted June 28, 2013 Author Posted June 28, 2013 It works fine. It was tested before it was sent out.... check out the terms for delivery too
