Burt-21 Posted June 30, 2013 Posted June 30, 2013 So does any one know if the valves in a 4efe are the same as a 4efte thanks Quote
AdamB Posted June 30, 2013 Posted June 30, 2013 Yes same. The 4EFE and 4EFTE use exactly the same head. Quote
TurboTobz Posted June 30, 2013 Posted June 30, 2013 Springs are different would advise you to use fte springs if your building an fte Quote
Rob H@RCH Engineering Posted June 30, 2013 Posted June 30, 2013 theres is a big difference in the n/a springs and the turbo springs. the n/a ones are longer and thinner the turbo ones are thicker and shorter. Quote
Burt-21 Posted July 1, 2013 Author Posted July 1, 2013 Thanks guys big help can start getting it all sort now Quote
