jmmy6990 Posted July 3, 2013 Posted July 3, 2013 hi, anyone on hear actually put an ep82 into a 91 sr using the sr loom and can help me out with what needs doing with the 2 looms, everything's in just the wiring to sort thanks Quote
bucketep91 Posted July 3, 2013 Posted July 3, 2013 Its been covered loads of times mate. There are different ways of doing ot but buying a crashed or auto glanza is the best/cheapest way to do it and swap everything over and sell whats left Quote
jmmy6990 Posted July 3, 2013 Author Posted July 3, 2013 i wer trying not to do that cause ive got everything 4 a ep82 engine now n were planning on just adding the extra wires needed on to my a 4efe sr loom but needed to no what else needs to be change as im doing it this week but thanks anyways pal Quote
RobSR Posted July 13, 2013 Posted July 13, 2013 (edited) Compare the pinouts of the ecu, I cant remember exactly off the top of my head now, but you need to splice in the Distributor, ignitor and coil, knock sensor, and swap a few other pins around and that was the main lot. Map sensor is different also. Have a look online as all the pinouts are there. The N/a and ep82 loom is very similar. Edited July 13, 2013 by RobSR Quote
jmmy6990 Posted July 14, 2013 Author Posted July 14, 2013 yea that wot ive been doing just a couple of things r confusing me like does the hvac after been run, does subharness after be used and y does one of the cables that comes off throttle position sensor run to the fan relay on the n/a ep91 loomthanks 4 the post tho rob Quote
RobSR Posted July 14, 2013 Posted July 14, 2013 Its no doubt the ground for the TPS. On the GT loom the ground comes from the water temp sensor, which is spliced with the ground from the TPS, then the MAP then goes to pin 16 on the 26 pin connector on the ecu. does the hvac after been run, does subharness after be used I didnt understand these two tho? what you mean? Quote
mikey4410 Posted July 14, 2013 Posted July 14, 2013 infinitely easyier to swap a whole loom.even better.seriously,i should know.lol Quote
RobSR Posted July 14, 2013 Posted July 14, 2013 infinitely easyier to swap a whole loom.even better.seriously,i should know.lol Thats the way i did it the first time and i thought it was abit of a pain seeing as you have to rip the whole car apart to change them all, aswell as when i did it sourcing them all was abit of a mission aswell. Looking at the diagrams, i think splicing all in all would be quicker and easier. Thats the way im going to do it next time.. Quote
mikey4410 Posted July 14, 2013 Posted July 14, 2013 i got hold of a full working mot and taxed donor car.was a recker though,but hd the bits i needed Quote
jmmy6990 Posted July 15, 2013 Author Posted July 15, 2013 il check if it a earth hvac is ment to b the thing that controls idle when air con is turn on n the sub harness connection is the two sensor that come off vaccum line which is on back of inlet manifold mikey i wer gonna do it that way but had all parts for ep82 n looked easy just to change a couple of pin about but thanks for your input Quote
mikey4410 Posted July 15, 2013 Posted July 15, 2013 Okies man,wish u all the best,hope all goes well Quote
