glanza sheehy Posted July 11, 2013 Posted July 11, 2013 right people cant seem to figure this out. i got a sub and amp wired up in my glanza , but a few days later it started to drain the battery ? so we then put a switch into the car so i could turn off the sub and amp once the car is stopped, this lasted a week untill the battery went dead again.. my alternator is starting to act up at late, so would that have anything to do with it? any info appreciated Quote
Mr. Chem Posted July 11, 2013 Posted July 11, 2013 What is the condition of the battery? How many volts? What is the voltage when the car is running? It may just be coincidence that the fitting of your sub has coincided with a failing alternator/battery Quote
glanza sheehy Posted July 11, 2013 Author Posted July 11, 2013 battery is as good as new so i doubt thats the problem? Quote
russ78 Posted July 11, 2013 Posted July 11, 2013 make sure remote is wired to orange wire on the radio loom bud Quote
Mr. Chem Posted July 11, 2013 Posted July 11, 2013 Some stereos I've found have permanent live remote cables for some reason. Does the battery still go flat if you disconnect the remote? You do really need to check the alternator is outputting enough voltage though. Anything less than 13.5V is bad Quote
mikey4410 Posted July 11, 2013 Posted July 11, 2013 A sub draining a battery,ure alternator has failed,simple. Quote
Dan Barnes Posted July 11, 2013 Posted July 11, 2013 It could be wired wrong and is staying permanently live draining it over night Quote
glanza sheehy Posted July 11, 2013 Author Posted July 11, 2013 not pernamently draining as there is a switch and the lights go off on amp and sub, il go with changing the alternator and see from there Quote
StuDoc 72 Posted July 11, 2013 Posted July 11, 2013 (edited) dont just dive straight in. A multimeter is cheaper than an alternator and its a great tool to have. Check the voltage between your battery with the engine running if its around 13.5 - 14 volts your alternator is fine. A wire could have shorted in your amp and draw a small amount of power. How quickly does it drain? Does the battery go flat when your driving? Because if it doesnt die when you are driving id be very doubtful about it being the alternator.Its far more likely to be the amp or the battery thats knackered.When you say your alternator has started to act up what do you mean by that? Edited July 11, 2013 by StuDoc 72 Quote
glanza sheehy Posted July 11, 2013 Author Posted July 11, 2013 the alternator has acted up by saying the car is jerking, conks and has to be jump started again Quote
asbo-v Posted July 12, 2013 Posted July 12, 2013 Go and get a power cap aswel 5 farad or 10 .i have one never a had a flat batt check the wires over ...... Quote
StuDoc 72 Posted July 12, 2013 Posted July 12, 2013 the alternator has acted up by saying the car is jerking, conks and has to be jump started again So it does conk out when your driving then? Quote
Taggy Posted July 12, 2013 Posted July 12, 2013 just check the voltage like Stu has said, then come back, running and not running Quote
glanza sheehy Posted July 13, 2013 Author Posted July 13, 2013 So it does conk out when your driving then? yes it does Quote
Xpect Posted July 13, 2013 Posted July 13, 2013 Have the same issue, but with a worn Battery. As my engine is dead atm my dad said my sub was draining all the power, which technically is not possible when Radio etc is off. But also if the Sub draws too much power by hearing loud music (and even without music sometimes) the electronics in the car would sometimes (very rarely) restart on their own without shutting down the engine. In my case this should be due to a dead battery, as I accidentally left the inner light on in winter and after draining all the energy the battery froze through (waited one and a half days to let it warm up in my living room and another day to charge it ) Well, as I have similar issues, I would say in your case the Alternator is knackered. Maybe the battery has some failure too, but certainly the sub has nothing to do with this, it's just there and as it's not stock people tend to say it's the reason for failure. Quote
StuDoc 72 Posted July 13, 2013 Posted July 13, 2013 If it dies when the engine is running then its the alternator. Possibly the bat aswell. Quote
glanza sheehy Posted July 13, 2013 Author Posted July 13, 2013 got an alternator just there lads, il keep ye posted how it goes next week thanks for the input Quote
