from factory they go on the inner/upper side of the lower dash plastics, not sure if the factory plastics to fit has little recesses or tabs to hold them in place or what, i know the OEM cowling for the illuminated ignition barrell is different to normal, its possible the footwell illumination was the same.
anyway, what i'm getting at is....lets take the passenger side...sit in the seat, your faced with the glovebox, beneath that there's a small lip of plastic i think off the top of my head, up on the inner side of that i think is where it went from factory. similarly on the driver's side, on the back side of the lower plastic that covers the steering column and houses that wee fuse box etc.
hope my rubbish description helps.
Phil.
Sweet, thanks lads :)
Haven't had time to have a look yet, I am getting some work done to the dash so when that's out I will have a little sort out of the mess that is the wiring behind it!!!!
