Malcolm GT Posted July 17, 2013 Posted July 17, 2013 If I want to take the whole turbo unit off. Is it just the 6 bolts on the block and manifold and then undo decat? What else do I need to be warey of Quote
Malcolm GT Posted July 17, 2013 Author Posted July 17, 2013 So you just pop them out, obv would have to empty water and oil and top up again when done? Quote
RobSR Posted July 17, 2013 Posted July 17, 2013 you dont technically have to drain the whole oil and coolant system, a little oil will dribble out the return when you take it off. Just be careful with the oil feed. they are prone to getting damaged easily and then leaking. Quote
Malcolm GT Posted July 18, 2013 Author Posted July 18, 2013 you dont technically have to drain the whole oil and coolant system, a little oil will dribble out the return when you take it off. Just be careful with the oil feed. they are prone to getting damaged easily and then leaking. thanks mate, got it changed recently due to it splitting so hopefully wont! Quote
