fufu32a Posted July 18, 2013 Share Posted July 18, 2013 when i pushing up the car, the engine lights will flash, then i go to check the car computer, it said the turbo sensor problem, but i dont know where it is. Every times lights on i will restart the engine, that was gone, anyone know how to fix it? thank you Quote Link to post Share on other sites
Socks Posted July 18, 2013 Share Posted July 18, 2013 Hi Mate... It sounds like your on the early stages of fuel cut! Fuel Cut is a limiter designed to protect the engine from being damage from building too much boost pressure... If you creep up to 0.9 bar of boost, you will sometimes get a EML light. Anymore, you'll fit fuel cut itself which will feel like a missfire... Have you got a boost gauge, what boost level are you running? Is the car stock? Quote Link to post Share on other sites
fufu32a Posted July 18, 2013 Author Share Posted July 18, 2013 Yes...i can feel fuel cut when that light on, , i see it arround 0.8bar boost for that, and sorry for my explain is so hard to understand for you and my english is not good. Quote Link to post Share on other sites
Socks Posted July 18, 2013 Share Posted July 18, 2013 Its fine, your doing well so far! Ok, if your hitting fuel cut then your building too much boost pressure. Is the car standard, if not what modifications have you done? Quote Link to post Share on other sites
fufu32a Posted July 19, 2013 Author Share Posted July 19, 2013 Thank you for your understanding. The car almost stock for engine, the turbo is stock, just change suspension, and exhaust, boost gauge, HKS BOOST CONTROLLER, TURBO TIMER. Quote Link to post Share on other sites
Liam_D Posted July 19, 2013 Share Posted July 19, 2013 Yep, as Matt said above it sounds a lot like fuel cut. My bet would be on the exhaust mods causing it, does it have a decat? Quote Link to post Share on other sites
fufu32a Posted July 19, 2013 Author Share Posted July 19, 2013 decat? Quote Link to post Share on other sites
Liam_D Posted July 19, 2013 Share Posted July 19, 2013 On the exhaust, have to removed the catalytic converter and fitted a straight threw pipe? Quote Link to post Share on other sites
fufu32a Posted July 20, 2013 Author Share Posted July 20, 2013 O....yes it have..... Quote Link to post Share on other sites
Liam_D Posted July 20, 2013 Share Posted July 20, 2013 it'll probably be that. Mine starting fuel cutting when i decatted mine. Quote Link to post Share on other sites
