My temperature gauge needle has started going up and down on some occasions not by very much though and it never goes above half way, coolant level is topped up to how it should be, I've bled the system also but I can't put it down to what else it could be? I'm thinking coolant temp sensor? If so where can I buy a brand new one from?
if its just the gauge on the cluster i would check the wiring first as the single wire for the gauge can get very brittle and cause breaks in the actual wire itself casuing it loose connectivity whn driving or going over small bumps.
