You still running a PCV mate?
Failing that it's down to a cylinder sealing issue as to why there's too much crank case pressure.
I've seen the PCV give similar problems before, but it does close under boost, meaning you only have the one breather working.
It's just a one way check valve, believe you should be able to blow through one end and not the other like. Although if you pull it out, you'll likely have to get a new one as they tend to break quite a lot.
I'd also do a compression test just to make sure.
Edited by AdamB
