WallaceGlanza Posted September 28, 2007 Posted September 28, 2007 My passenger side window doesn't work, neither of the switch's work. Fortunately the window is up at the moment though!I currently have the doorcard off looking for any obvious loose wires but can't see any, the motor doesn't make any noise when the switch is flicked either.Is there anything else I can check for, I don't have a voltmeter unfortunately so can't test to see if there is power to the motor.I know that one guy had a problem with his window at the scottish meet earlier this year, can't remember who it was though.Any common problems that it could be? Quote
ady Posted September 28, 2007 Posted September 28, 2007 listen reeeeaally close and carefully while you press the button, if the motor is jammed you should hear a little click as it tries to move. Quote
WallaceGlanza Posted September 28, 2007 Author Posted September 28, 2007 Thanks for the advice but i have now resolved the issue.Mods you can delete this please.Jay don't comment, I can see you lurking in here. Quote
tr1cky Posted September 28, 2007 Posted September 28, 2007 first thing check for a power supply to the motor while pressin the switch, if u got power there then its more than likely the motor is fucked or theres a bad earth. if theres no power check the fuses, check the connection on the window switches on both sides. if thats all good its probably a faulty window switch. Quote
Glanza_Ragger Posted February 17, 2008 Posted February 17, 2008 Thanks for the advice but i have now resolved the issue.Mods you can delete this please.Jay don't comment, I can see you lurking in here. How did you resolve it bud? Quote
WallaceGlanza Posted February 17, 2008 Author Posted February 17, 2008 How did you resolve it bud?Pm'd mate. Quote
Glanza_Ragger Posted February 17, 2008 Posted February 17, 2008 Pm'd mate. Awesomeness, thanks darling ;) Numptys haha Quote
Glanza_Ragger Posted February 17, 2008 Posted February 17, 2008 Youre my hero!Now i wont have to take a hammer to the door Quote
