gtt Posted September 30, 2007 Posted September 30, 2007 hi has any one got a wireing diagram for fiting a emanage bule with the injector harness and ignition to a starlet ep82. thanks Quote
WallaceGlanza Posted October 1, 2007 Posted October 1, 2007 Here is the wiring diagram I did for my glanza using both the ignition and injector harness's:Then this diagram shows the three different ecu's for the 4efte starlet, T-6 is for the MT EP82 Mk1-3 (89-95) and AT EP82 Mk1-2 (89-91)T-7 is for the AT EP82 Mk3 (92-95) (Quadlight)T-9 is for the EP91 both MT and AT[Click on either image to enlarge]So simply select the ecu suited to your GT then alter the diagram to suit. Quote
parko Posted March 24, 2011 Posted March 24, 2011 Here is the wiring diagram I did for my glanza using both the ignition and injector harness's:Then this diagram shows the three different ecu's for the 4efte starlet, T-6 is for the MT EP82 Mk1-3 (89-95) and AT EP82 Mk1-2 (89-91)T-7 is for the AT EP82 Mk3 (92-95) (Quadlight)T-9 is for the EP91 both MT and AT[Click on either image to enlarge]So simply select the ecu suited to your GT then alter the diagram to suit.i know this is an old post but dont suppose anyone can find this info? would be pretty helpful Quote
bucketep91 Posted March 24, 2011 Posted March 24, 2011 on the menu on the sidebar click on e-manage forums you should find what you need in there Quote
Sparky Posted March 24, 2011 Posted March 24, 2011 Or go to greddy and download the complete instruction manual off the site Quote
parko Posted March 25, 2011 Posted March 25, 2011 Or go to greddy and download the complete instruction manual off the site downloaded it from greddy but doesn't include starlets in there. yeah i have just joined and left a thread on the e manage fourm but no reply. doesn't look like its used much?? Quote
Sparky Posted March 25, 2011 Posted March 25, 2011 I have all the info you need mate, if you can wait till later I will email it over to you.Starlets are in the manual though, well in the copy I have Quote
parko Posted March 25, 2011 Posted March 25, 2011 I have all the info you need mate, if you can wait till later I will email it over to you.Starlets are in the manual though, well in the copy I haveyeah no problem that would be sweet mate, cheers hmm not sure what manual i have then lol Quote
GTnomez Posted May 13, 2011 Posted May 13, 2011 Spark, do you still have the info?Parko is right, i cant find fack all and if i do i have no idea to make sense of it LOLI found your thread though parko and im just reading up on it now. Quote
ep_brad Posted May 13, 2011 Posted May 13, 2011 try thishttp://www.austarletclub.com/forums/index....showtopic=13602 Quote
GTnomez Posted May 13, 2011 Posted May 13, 2011 Brad..............FARKING BRILLAINT!!!!CheersRepped (not really lol) Quote
Starbuck Posted May 13, 2011 Posted May 13, 2011 Thats the one i used GT. (mentioned in the PM i sent) Quote
parko Posted May 16, 2011 Posted May 16, 2011 Hey guys,i got together everything i found and put some pretty useful info/ pinouts for the EP82 on the emanage site (<<<< under board links) might help someoneParko Quote
GTnomez Posted May 16, 2011 Posted May 16, 2011 I wired up an emanage gold using the austrailian diagram. I followed it exactly using the pinout from both ends (the ecu and the emanage) BUT the harness on the gold had different colours to the one on the blue.E.g it would say, "yellow/black to pin 25" but the gold would be "orange/red", does it really matter as i wired it all up regardless. Quote
