hlep fiting emanage bule
Here is the wiring diagram I did for my glanza using both the ignition and injector harness's:
Then this diagram shows the three different ecu's for the 4efte starlet,
T-6 is for the MT EP82 Mk1-3 (89-95) and AT EP82 Mk1-2 (89-91)
T-7 is for the AT EP82 Mk3 (92-95) (Quadlight)
T-9 is for the EP91 both MT and AT
[Click on either image to enlarge]
So simply select the ecu suited to your GT then alter the diagram to suit.:)
  • 3 years later...
i know this is an old post but dont suppose anyone can find this info? would be pretty helpful
  Sparky said:
Or go to greddy and download the complete instruction manual off the site :)
downloaded it from greddy but doesn't include starlets in there.
yeah i have just joined and left a thread on the e manage fourm but no reply. doesn't look like its used much??
  Sparky said:
I have all the info you need mate, if you can wait till later I will email it over to you.
Starlets are in the manual though, well in the copy I have
yeah no problem that would be sweet mate, cheers :)
hmm not sure what manual i have then lol
  • 1 month later...
Hey guys,
i got together everything i found and put some pretty useful info/ pinouts for the EP82 on the emanage site (<<<< under board links)
might help someone
Parko
I wired up an emanage gold using the austrailian diagram. I followed it exactly using the pinout from both ends (the ecu and the emanage) BUT the harness on the gold had different colours to the one on the blue.
E.g it would say, "yellow/black to pin 25" but the gold would be "orange/red", does it really matter as i wired it all up regardless.
