Just opened up the side of the seat where a seatbelt clip (the bit with the press button) bolts to, but there's no where I can bolt it to!
Is anyone using stock seatbelts with Recaros? If it makes any difference mine are Evo 4 Recaros. I thought about using the transmission tunnel bolt for the seat rail as a belt mounting point but it doesn't seem safe and probably wouldn't even fit in there!
Help please! Would really like to get this seat in without the hassle of using harnesses again!
Thanks
Amjad
i used the tunnel thingy for seat rail, i had to remove the handbrake plastic surround.
under the plastic there's 2 bolts for handbrake mounting, u could probably get a bracket made up from there for the clip to be extra safe.
will sit a bit high tho.
I used the same place in the end!
They both bolt to the rails on mine. ZEP rail and a Recaro rail. EVO4's too, nice seat.
The rails are custom fabricated ones, not really anywhere to mount them but I used the tunnel area for now! :)
Nice one guys!
