I just assumed it was crank seal since it seems commen lol my clutch don't slip though but there's a shit load of oil that comes out that area and is getting worse
Check the sump area or just whip the box
Out then you'll be able to tell straight away. if its getting worse I'd do it sooner rather that later because it could contaminate your clutch then it's expensive :(
It's been leaking since I've had the car but now it's noticeably dripping, I've gave up on it now and just treat it like a rag around tbh so booking it in for a garage to sort as I cba to waste time on it any more
Same with mine it's been like it since I've owned it fair shout mate I'd book mine in if I had the £s lol
I normally don't mind doin it and would easily take it in work and changeit but got not go in me to do it lol
If theres a drip of oil hanging off your gearbox its usually always the crankseal. A seal is like £5 from the local motor factors so your just paying labour.
Use a good garage and get a receipt because if the seal is a poor fit you have warranty and if they dont TORQUE the rear gearbox mount bolts properly the box will split (another very very common problem) ECC in Ireland make a brace for it because its so common
