PaulStarletSR Posted August 9, 2013 Posted August 9, 2013 so until i check for engine fault codes 2moz, im gona guess 1 of the problems I've got is the fact that said sensor above has NOT been plugged in as im sure I've got the wrong 1 for my loom. i have a grey triangular sensor on the engine and need 1 thats not triangular, anyway the point in this post is to find out if this loom plug is the right 1 so all i need to do is get the right sensor. loom plug that seems to sit perfectly at the sensor i believe is thr wrong 1 for the engine: Quote
PaulStarletSR Posted August 9, 2013 Author Posted August 9, 2013 also, here is the sensor that im sure is the wrong 1 as no plug I've got left on the loom fits! Quote
Hawwy Posted August 9, 2013 Posted August 9, 2013 That wrong one you need one like:http://www.camskill.co.uk/m19b0s1301p48340/Toyota_Starlet_Turbo_%5BEP82_EP91%5D_-_Parts_Spares_Tuning_Servicing_Accessories_-_Engine_Coolant_Temperature_Sender_-_Starlet_Turbo_up_to_05_1997 Quote
PaulStarletSR Posted August 9, 2013 Author Posted August 9, 2013 nice 1 bud! can this be partly the reason y the engine management lights on? perhaps contributin to the idle issue? Quote
