Best place to use trolley jacks on front
I usually use the toeing eye to jack and under the back of the wishbone for the stand. If you have a jack with the rubber pad then you can jack off of the center of the cross member
The sills just get bent if using trolley jacks without rubber pads on them
Edited by morgey
