JayJ Posted August 10, 2013 Posted August 10, 2013 As you can see from the image the gasket has a small groove, so which side should be facing to the turbo and which to oil feed flange? Quote
JayJ Posted August 11, 2013 Author Posted August 11, 2013 If you mean those holes, yes it will fit only one way, but you can still flip the gasket. One side has groove and the other side has bulge around the feed and return holes Quote
mattglanza79 Posted August 12, 2013 Posted August 12, 2013 The turbo flange should show you how to fit. On mine you could see the outline of the shape ! Quote
JayJ Posted August 12, 2013 Author Posted August 12, 2013 I checked two of the turbos I have and both have had the gasket different way lol. So I put the side 1 facing the turbo and side 2 facing the oil feed flange. Seems to be ok, not leaking. Quote
