5efhe cams.4efte engine....4e or 5e settin??
Should be set to 5E mate, that's the way I figure it anyway. The cam specs are different, therefore should be set to the 5E mark. Saying that when changing cams they should be dialed in with a DTI if you want it accurately done.
Yeah there's a wax stat on the TB which allows air to bypass to the ICV I believe.
Edit.
More info here
http://www.toyotagtturbo.com/forums/showthread.php?102783-Wax-Stat-help&highlight=stat
http://www.toyotagtturbo.com/forums/showthread.php?102228-When-you-think-your-getting-somewhere!!!&highlight=stat
Edited by AdamB
I wouldn't have thought it would cause the idle to fluctuate. Do you have the filter/ damper in the map sensor pipe? And when the wax stat in the tb goes that usually give you a high and annoying idle. You got the temp sensor sorted? You could just be getting a bit of a lean missfire
