Calling south west ukso members
Basically I'm after a favour,
My coilovers arrived today and I decided to start at the rear because they are the worst however that's where the problem is....... The shock nuts won't fucking come off no matter how hard I try :(
Has anyone in the south west ( weston Bristol or Taunton ) got a workshop or air gun set up that could help out?
I contacted my local garage and they wanted wait for it £45 a side so £90 all in for replacing two shocks !
Thanks in advance James
If you unbolt the tops of the struts the whole beam drops the near side is easier its the offside that's the problem cuz of the exhaust etc but I used a breaker bar on mine it was hard but did work
Get a decent ratchet and a scissor jack, push ratchet onto bolt so pushin it up will loosen the nut and start winding that scissor. Alternatively if you can't find a place to push up to get it off put the jack on the bottom of the car so it's upside down and try again. I've got loads of shit off like that lol
