stup86 Posted October 11, 2007 Posted October 11, 2007 I was wondering if it was possible to change the stop position of the rear wiper.I'd like it stop horizontal rather than upright (not sure if any of your guys have thought this!?!)Anybody have any ideas?CheersStu Quote
Rich Posted October 11, 2007 Posted October 11, 2007 Im sure you can fit a wiper arm from another car (not sure if its a punto or not...)Rich Quote
stup86 Posted October 11, 2007 Author Posted October 11, 2007 pull it off, turn it round put it backThat will work, but only visually.When I use the rear wiper it will start wiping the bootlid, lol.Did think of doing it though! Quote
DavidAshton Posted October 11, 2007 Posted October 11, 2007 Check this thread, shows you two options although no one quite knows which punto yet.Click Quote
Monkey Posted October 11, 2007 Posted October 11, 2007 That will work, but only visually.When I use the rear wiper it will start wiping the bootlid, lol.Did think of doing it though!What if you swap around the contacts to the wiper motor to reverse the current flow? The first signal it receives will then wipe upwards across the window? Quote
stup86 Posted October 11, 2007 Author Posted October 11, 2007 What if you swap around the contacts to the wiper motor to reverse the current flow? The first signal it receives will then wipe upwards across the window?I did think this, would it actually work? Theoretically it should. Anyone know if it would work? Quote
