Changing the rear wiper stop position
That will work, but only visually.
When I use the rear wiper it will start wiping the bootlid, lol.
Did think of doing it though!
What if you swap around the contacts to the wiper motor to reverse the current flow? The first signal it receives will then wipe upwards across the window?
I did think this, would it actually work? Theoretically it should. Anyone know if it would work?
